08-07-2018 11:06
08-07-2018 11:06
My Ionic will not sync to my phone anymore and I've only had this fitbit for about 2 months.
08-07-2018 13:22
08-07-2018 13:22
Same issue here. My Ionic has been working flawlessly up until yesterday (almost 8 months) when it stopped syncing, I noticed because the time was off by about 25 minutes.
I’m using an iPhone 7 Plus, and the Ionic shows up in Bluetooth, but won’t connect. So far I’ve done reboots of the phone, the Ionic, toggle Bluetooth, uninstalled/reinstalled the Fitbit app, removed device from my Fitbit account, and literally 5 factory resets and it always ends up in the same situation. This morning I tried one more time and it connected great throughout the setup process, but after it downloads updates and finishes the connection problems start.
Very frustrating to try so many different things and it just won’t work. Hopefully this is just a software issue and can be fixed with a patch.
Best Answer08-08-2018 07:06
08-08-2018 07:06
@KHarper2010 we would need to know what device you sync through.
@Marll she rry I don't know iOS and suggest looking at the iOS board for solved threads. I see many with a green check mark.
08-08-2018 07:28
08-08-2018 07:28
Best Answer08-08-2018 09:39
08-08-2018 09:39
@KHarper2010 here you go things to try
Have you looked at the help doc
Why won't my Fitbit device sync?
