09-21-2018
16:15
07:09
09-21-2018
16:15
07:09
Updated to IOS 12 now phone does not detect Ionic and owon't connect Bluetooth.Any suggestions on how to get it to connect?
09-24-2018 07:54
09-24-2018 07:54
Welcome @Bronlloyd, thanks for jumping in here! Thanks for taking the time to troubleshoot this on your own. Nice way to go!
While reading your post, my first thought is that your Ionic might be no longer paired to your Fitbit account and that's why it's not syncing or connecting to your phone's Bluetooth. In order to solve this, please go to the Bluetooth settings on your phone and remove the tracker. In the list of Bluetooth devices you'll see the Ionic and next to it, this symbol "!". Hit the symbol and it will take you to the next step, once you're there select the option that says "Forget this device".
Once you've made sure about that, go back to the Fitbit app, go to the "Account" option in the upper right corner and select "Set up a Device". This should start the setup process for your device. ![]()
Give this a go and let me know if the inconvenience persists.
09-22-2018 07:04
09-22-2018 07:04
Welcome on board @jsanders124242, it's nice to see you here! Are you still experiencing the syncing connection with your Ionic?
If you are, I'd recommend the following:
Try to sync after doing each of the steps above. That should certainly help you out with this.
Hope this helps. Let me know how it goes! ![]()
09-22-2018 08:11
09-22-2018 08:11
Hi, I bought a Fitbit Ionic with great expectations, only to find myself highly disapointed right now 😞
I can connect my iPhone 8 (ios 12 and latest Fitbit app) to the Ionic without issue then it updates itself to v27.32.10.20 and the troubles start, first my phone tells me the update failed but the Ionic says its on that version... My iPhone is unable tot connect to the Ionic from that moment on and keeps trying to sync without succes.
Following all the instructions on your support site also gives no result. Rebooting all devices, removing the device from both Fitbit app and devices results in the fitbit app hanging stuck after entering the pair code... Pls help
Best Answer09-22-2018 08:50
09-22-2018 08:50
Welcome here @svg007, I'm glad to have a new member around! Thanks a lot for taking the time to troubleshoot this syncing issue on your own. Nice way to go!
It seems you've exhausted all the steps in order to fix this, so I have reached out to our support team and created a case regarding your inquiry. Someone will be reaching out to you within the next 24-72 hours with next steps. ![]()
If there's any questions present, let me know.
09-23-2018 09:17
09-23-2018 09:17
I’ve been having the same issues and have done everything that has been recommended as well. It will connect once after a disconnection and reconnect and then won’t do it again.
Best Answer09-24-2018 07:54
09-24-2018 07:54
10-01-2018 03:47
10-01-2018 03:47
My Fitbit Ionic is not even showing up on my list of Bluetooth devices 😞
J. Paul
Best Answer10-01-2018 05:37
10-01-2018 05:37
Thanks for stopping by @jpaulmoore! Hmmm... that's very strange. Can you please send me a screen shot of your phone's Bluetooth settings?
If your Ionic is no longer paired, please see: How do I set up my Fitbit device? to add your tracker again.
Looking forward to your response! ![]()
Best Answer10-03-2019 09:51
10-03-2019 09:51
Just updated to ios13 tried turning both iconic and Bluetooth off and tried to re-pair but doesn’t find the device
