06-24-2018
19:43
10:20
06-24-2018
19:43
10:20
Can't sync fitbit Ionic to Galaxy S8.
Have:
my phone recognises the Ionic in the bluetooth tray, but the app won't.
All the above about 50 times. The time on the device is wrong, so this glorified paperweight isn't even useful as a watch. Is there a fix or was this a several-hundred-dollar scam?
Best Answer06-25-2018 10:21 - edited 02-11-2024 11:12
Hey there @AlexCattoo, thanks for stopping by and for troubleshooting this syncing inconvenience already, nice way to go!
While reading your post, my first thought is that your Ionic might be no longer paired to your Fitbit account and that's why it's not syncing or connecting to your phone's Bluetooth. In order to solve this, please go to the Bluetooth settings on your phone and remove the tracker. In the list of Bluetooth devices you'll see the Ionic and next to it, this symbol "!". Hit the symbol and it will take you to the next step, once you're there select the option that says "Forget this device".
Once you've made sure about that, go back to the Fitbit app, go to the "Account" option in the upper right corner and select "Set up a Device". This should start the setup process for your device. ![]()
If you can't get started with your Fitbit device, usually a missing requirement is the cause. Carefully review the requirements below, if you're using the Fitbit app for iOS, Android, or Windows 10:
If you're still unable to set up, try these troubleshooting steps:
