08-13-2018 12:31
08-13-2018 12:31
New Ionic Fitbit and it will not comnnect to my wifi, which is with sky so there shouldn't be a problem. My iPhone and iPad are connected without a problem!
Best Answer08-13-2018 18:47
08-13-2018 18:47
See this article:
https://help.fitbit.com/articles/en_US/Help_article/2233/?l=en_US&p=ionic&fs=Search&pn=1
There are certain wi-fis that the Ionic will not connect to. Check your router and make sure it is a 2.4 Ghz or dual band router. If it is a 5 Ghz one then it won't connect.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
08-13-2018 18:55
08-13-2018 18:55
With as long as 5 Ghz has been out I'm totally shocked it won't work with that.
Best Answer08-14-2018 02:54
08-14-2018 02:54
Best Answer08-14-2018 04:35
08-14-2018 04:35
It is not your broadband but the router that sends out the wi-fi signal. I would suggest first checking the unit to see if it has anything on the case to tell you. If not, note the manufacturer and the model number and then check the internet for the user manual which should tell you.
08-14-2018 09:03
08-14-2018 09:03
Best Answer08-14-2018 09:32
08-14-2018 09:32
It isn't a 2.4ghz router but it still won't connect
Best Answer08-14-2018 16:52
08-14-2018 16:52
@Gilly1234 I assume you mean you have 2.4 Ghz. If so look at the following link and work through the steps to see if it will connect:
https://help.fitbit.com/articles/en_US/Help_article/2249?p=ionic&l=en_US&fs=Search&pn=1
If you actually have a 5 Ghz router then it will not connect to that. In my case, I needed a range extender for my house becasue the line came in at one end of the house and the signal was iffy at the other end. I just purchased a dual band extender that automatically detected the band needed and linked up. I have had no issues with the Ionic on that.
