What does the middle stat mean on the exercise app.
I can’t customize it .. I can customize the top and bottom stat
Thanks
Knew owner thx
Best AnswerThe middle stat you can change on the device whilst your exercise/workout is active. The top and bottom stats are fixed to whatever you set in the menu and cannot be changed while a workout is active. You can cycle through the available middle stats by pressing the left button or tapping the screen.
The options for middle stats in the options menu (gear icon ⛮) you are referring to just allows you to add/remove which stats you'd like to be able to cycle through during workouts.
I dont understand. On the Fitbit App or The Ionic?
Please be specific so we can help better
Wendy | CA | Moto G6 Android
Hi,
I've managed all that, even deselected the ones I don't want visible in the middle stat but my ionic still seems to reset each time I use it, similarly with the top & bottom ones which I am continually setting prior to each exercise. Can these be permanently set. Firmware on my ionic is 27.32.10.20
