01-10-2020
11:55
15:43
YojanaFitbit
01-10-2020
11:55
15:43
YojanaFitbit
I have reviewed and tried all of the tip if the troubleshooting guide. Still have battery and connecting issues. Also I am having a issue with tracking distance for the preset exersizes. The distance on the eliptical are about 30% more then the machine shows. Distances on the treadmill appear about 30% less then the machine indicates. I have made sure my stride lengthes are correct and typicall use the both machines with my arms moving.
Best Answer01-10-2020 22:09
01-10-2020 22:09
The stride length is for walking outside.
Are you holding on the bars? If so it need to see the arms swinging
Also you need to realize on the elliptical and treadmill you are not going any where. Your in the same spot how can it calculate distance?
See this thread by MrMarv It explains it very well
Another good thread to read on treadmills
Wendy | CA | Moto G6 Android
