No Notification of Incoming Call yet sync is fine
Ok I posted yesterday that the Ionic works fine with the ZTE N818S phone
Well that was until today when it failed to notify me of 2 incoming calls
Now I have seen post of problems happening after updating to the new software ?
The Ionic is no good if it won't notify me of calls
I made sure what apps on my phone can send notifications so it should be working
I want it to let me know of incoming calls that was one of the reason to get it
So I know when calls come in since I'm hearing impaired
2 REPLIES 2
Hold the single power button on the left side and make sure notifications are turned on
Have you checked the Fitbit app permissions?
I usually disable then re-enable notifications on the Fitbit app. This forced the phone to ask the user to enable the required permissions.
