06-28-2019 11:47
06-28-2019 11:47
I just purchased my Fitbit ionic a little less than a month ago. It worked perfectly for the first week and now it won't clear old messages and email notifications. I have tried rebooting it and it does reset but then it happens again and I have to keep rebooting it. Does anybody know how to fix this issue?
Best Answer06-28-2019 12:07
06-28-2019 12:07
Which notifications are you refering to @Alwaysashleighl? on the Fitbit app or ionic.
On ionic press Clear All or swipe the notification off the screen.
If the notification comets back it is because the Fitbit app has resent and it would be help full to know which phone and app that the notification originated from and if the notification was marked as read.
If not marked read, the app sending the notification might be the issue.
Best Answer06-28-2019 12:34
06-28-2019 12:34
Best Answer06-29-2019 12:10
06-29-2019 12:10
Hi, I'm having the same problem on my Versa. I have a gmail message that I keep clearing on my Versa (and have deleted from gmail), but it keeps showing up in my notifications.
