10-29-2017 17:15
10-29-2017 17:15
How do you find the settings on the Fitbit app for Pandora? Each time I go to the app it doesn't show a setting option to add stations.
11-01-2017 08:28
11-01-2017 08:28
Are you using the free version of Pandora? If so, it will not work with the Ionic.
Best Answer11-01-2017 12:22
11-01-2017 12:22
Best Answer11-01-2017 13:31
11-01-2017 13:31
If you get the $5/month deal (like I did), it will sync the top 3 stations that you've created.
All the station management is done on the Pandora app/web site. The Ionic merely does the syncing.
Once your Pandora account is set up, here's how you get the music to the Ionic
| To download Pandora stations: |
1. If you haven’t already done so, make sure Ionic can connect to your Wi-Fi
network:
a. From the Fitbit app dashboard, tap or click the Account icon ( ) >
Ionic tile.
b. Tap or click Wi-Fi Settings.
c. Tap or click Add Network and follow the on-screen instructions to
connect to your Wi-Fi network. For best results, use your home or work
Wi-Fi network.
2. Go back to the dashboard and then tap or click Media.
3. Tap or click Pandora.
4. Follow the on-screen instructions to log into your Pandora account. If you
don’t have a paid Pandora subscription, upgrade your existing account or
create a new account and then return to the Fitbit app to complete the setup.
5. In the Fitbit app, choose to auto-sync up to 3 of your most-played Pandora
stations or manually select up to 3 Workout stations. If you have Thumbprint
Radio on your Pandora account, it also downloads to your watch regardless of
which option you choose.
6. Plug your watch into the charger. Stations download automatically when the
watch is charging and in range of your Wi-Fi network, or tap Force Sync Now
in the Fitbit app to add the stations to your watch.
11-24-2017 09:49
11-24-2017 09:49
Tried every recommendation, still can't get 2 pandora stations on ionic. Got one and then upon the attempt to get a second....Lost both!!! Got over 25 hours in it already. Anyone tried it under a full moon? I open to near bout anything at this point.
Best Answer11-24-2017 13:45 - edited 11-24-2017 13:47
@caveman11 wrote:Tried every recommendation, still can't get 2 pandora stations on ionic. Got one and then upon the attempt to get a second....Lost both!!! Got over 25 hours in it already. Anyone tried it under a full moon? I open to near bout anything at this point.
Hi @caveman11,
I don't see mention of a full moon sync in the documentation. If you try, it might be good to wear a necklace made of garlic. 😉
I did get 3 stations on the Ionic, but it took some effort. As far as I can tell, during the station update, it will wipe out any station before updating. So if the Pandora sync dies in the middle, it can end up with no stations on the Ionic.
So what helped?
One, was unlinking the Pandora account in the app. You'll need to log back into Pandora in the Fitbit app.
Two, is just leaving the Ionic on the charger overnight. When I woke up the next morning, I had 3 stations on the watch. Not sure how long it took for the Ionic to finally sync everything up. But it beat sitting there trying all kinds of things for a manual sync (I haven't had any luck with the Force Sync Now function in the app).
Hope there's something useful in this post.
11-24-2017 14:22
11-24-2017 14:22
Double check the wifi settings for the ionic. Agree the sync takes longer than it seems it should. I've had 3 stations on the ionic. Seems like about 50 songs per station (just a guess).
Best Answer11-24-2017 20:39
11-24-2017 20:39
I don't see the "media" buttonon the dashboard. #2 on your instructions?
Best Answer11-25-2017 09:33
11-25-2017 11:08
11-25-2017 11:08
Best Answer12-01-2017 18:29
12-01-2017 18:29
Yes, finally got 3 stations. Solution, prayer & fasting and leave it overnight.
12-01-2017 19:52
12-01-2017 19:52
@caveman11 wrote:Yes, finally got 3 stations. Solution, prayer & fasting and leave it overnight.
Good news. I can confirm that fasting is optional, as my Pandora is syncing fine on a caloric surplus. 🙂
@caveman11, do you have a station called Thumbprint Radio? Mine just showed up, from finally giving enough songs the "thumbs up". It looks like Thumbprint Radio now becomes one of the three stations?
Best Answer01-01-2018 11:21
01-01-2018 11:21
I been a Pandora subscriber and Blue Tooth user for over a decade.
This is impossible, erratic, and quirky.
Are we Alpha testing?
The download handshake is weak,
there is no way to assess the progress oft the install.
Initially the three canned Pandora programs loaded then completely disappeared.
I've wasted two days on this and cannot understand why Fit Bit would sell this product.
I have cleared the watch and done a factory reset.
I'm ready to return.
02-11-2018 09:52
02-11-2018 09:52
In Multimedia
Best Answer03-08-2018 14:11
03-08-2018 14:11
I been trying to get into my Pandora app on the watch and it say something logging into the app in the mobile app and I did tried logging in and its not working I even updated my Pandora subscription and still nothing tried shutting down the fitbit app still nothing. I am interested in getting the headphones but I cant even log into Pandora.
Best Answer03-31-2018 21:53
03-31-2018 21:53
I just got an ionic. I synched pandora stations on it. I want to go on a bike tour and wondering how many hours of music each station has without repeats.
Best Answer04-04-2018 12:37
04-04-2018 12:37
After I updated the app, my Pandora stations no longer appear on my Ionic and I have tried multiple times to sync them again to no avail. All i get is a spinning circle and am not prompted to enter my Pandora login and password.
Best Answer04-05-2018 07:10
04-05-2018 07:10
I have reset my Ionic, tried to sync my Pandora stations again and am still not prompted to log in to Pandora. How can this be fixed?
