Is quick reply supported for Telegram? The fitbit app is not recognizing Telegram as a text message app.
Has anybody got it working on their fitbit?
I'm using an LG G6 running android 8.0 and a Fitbit Ionic on OS 2.1. Quick reply works without any problem on messenger, whatsapp and text messages (berichten is Dutch for messages). Notifications of Telegram are showing, but don't show a reply button, only a dismiss button.
Thanks in advance!
Best AnswerIt doesnt seem to be, are you able to set Telegram as your defaults messaging app?
If not then this would explain why and something telegram needs to fix. If it does then Fitbit should be able to enable Telegram
Thanks for the answer, Rich_Laue. I really appreciate the help.
I'm not able to select it as my default messaging app, but neither am I with whatsapp. And quick reply works without any problem on whatsapp.
As far as I know I've checked all the settings I found with comparable problems (like with Textra), but so far nothing helped.
Don't know if it may add anything to this situation, but I was able to send quick replies with Pebble Time and Pebble Time Steel. (don't know about the previous editions)
Best AnswerSince that is the case @Ayrton_p with not being able to register the app as your default messenger. like Whats app, I suggest adding the request to the Feature Suggestion Board.
Let's see what others think.
Please also post a link here and I'll add my vote.
