After my first Ionic stopped working completely after 17 months Fitbit agreed to replace it. Received the new one today and started the set-up. Everything appeared to be fine and then the set-up said it lost the connection at 55% complete. My WiFi connection was working fine. App kept saying to keep the device close by which it was a couple inches away. It was just frozen for quite sometime.
Turned off the device and tried restarting and it won’t start at all. Just a blank screen. Battery was fine with my initial set-up attempt. Put the charging cable on again and there are not any lights.
I have tried a reset and still nothing. Not sure what to try at this point. BTW, was setting up to an iPhone.
15:11
07:57
10-17-2019
15:11
07:57
@Bruski105 It's great to see you around.
I appreciate the details mentioned and the troubleshooting tried. Sorry to hear that you're experiencing this with your replacement Ionic.
I've shared your post with our Support team and they've mentioned you already have a case with them, please continue the communication through email, they will continue assisting you.
I'll be around if you have any additional question.
Best AnswerEXACT same thing happened to me - replacement came...charged it for over 2 hours...began setup...said connection was lost, tho iPhone & Ionic were side by side. Now COMPLETELY DEAD - nothing I have tried with bring it back...HELP!
Best AnswerI received a 2nd replacement 2 days ago and the set-up worked. Things seem to be working ok but I noticed last night that the heart rate on the watch isn't working properly. If I open the app it shows the bpm but on the watch it's a constant number. I'm a little afraid to try a restart and have the watch brick again. It's a pain to have to keep reading the various forums in an attempt to get the watch to work as it should not to mention the time wasted.
