07-23-2020 00:47
07-23-2020 00:47
Hi I switched from a charge 2 to an ionic back in March. With this change my resting HR went up from 57/8 average to a 64 average. Is there a reason for this? Is the ionic reading differently?
16:40
12:27
07-24-2020
16:40
12:27
@Erikthebee It's nice to see you on the Community. Thanks for getting in touch about this.
Resting heart rate is the number of times your heart beats per minute when you are still and well rested. This metric can be an important indicator of your fitness level and overall cardiovascular health. The typical resting heart-rate range for adult Fitbit users is 50-90 beats per minute. Active people often have a lower resting heart rate. For more information, see the Fitbit Blog.
Fitbit uses your heart-rate data from when you’re both awake and asleep to estimate your resting heart rate. For best results, wear your device to sleep.
I would like you to try the tips on this article about factors that can affect your heart-rate reading on your Fitbit Ionic. Once you've checked these tips, try it out for a couple of weeks and see if it changes.
I'll be around if you have any additional questions.
Best Answer07-25-2020 00:36
07-25-2020 00:36
Best Answer07-25-2020 00:38
07-25-2020 00:38
thanks for the message and article. I read the article and it is not relevant to what I have written.
16:31
12:27
07-29-2020
16:31
12:27
@Erikthebee Thanks for getting back.
In this case, I've shared your post with our Support team and someone will reply to you as soon as possible. Keep in mind that due to recent events affecting our operations, we may take a bit longer to get back to you.
