Hi all. I am trying to up my time and distance for running. I want to use the interval time feature on my ionic. But, I can't change any of the options - Move, rest and laps times. Is this possible to change? Any other ways I can do interval time running using fitbit (besides manual stop and go). Thanks
Hey, @chasmasb great to see you on the Community!
These settings can be changed by visiting your settings found on the online dashboard. Click on the Ionic tab and you should see a drop-down for your interval timer where these settings can be changed.
Also, there is a great 'Ionic 101 guide' that is located under the Ionic tab on your settings page which has some solid tips and tricks for the different features it has. I recommend checking it out if you have not already. ![]()
Hope this helps! If you have any additional questions, you know where to find me!
Want to get more deep sleep? Join the discussion on our Sleep better forum.
