10-30-2018 01:13
10-30-2018 01:13
I want to have the new Sony XZ3 phone next month but can't see it listed in compatible devices!!!!! Has anyone got one and will it sync, receive notifications etc?
10-30-2018 09:25
10-30-2018 09:25
Hello @Hippy996 have you done a search of the Fitbit's boards yet? Many times a search will give the answer
10-31-2018 01:32
10-31-2018 01:32
Yes i had already searched but as it is a relatively new phone and I guess not a mainstream phone there isn't any info.......Thanks anyway 🙂
10-31-2018 03:05 - edited 10-31-2018 03:05
This link gives you the comparison between my XA2 and your proposed XZ3,
This link gives my findings in the Android forum.. I don;t use music and minimal GPS. Everything else works on my Ionic and One
There are some posts about Android 9 (Pie) which the the XZ3 has been released with.
10-31-2018 09:44
10-31-2018 09:44
11-02-2018 17:37
11-02-2018 17:37
@Hippy996 Please keep us posted... I have been a Sony user since Blackberry "lost the plot".
From the last App 2.82 and on my Sony XA2 with the Ionic I now have to be careful of deleting my emails via the Ionic, because it now works... Fortunately the emails finish up in trash in my Outlook on the phone..
11-04-2018 14:22
11-04-2018 14:22
Bought the xz3 with Android pie and working just fine (at the moment). Thanks for all the replies 🤗
11-04-2018 18:18
11-04-2018 18:18
@Hippy996Thanks for getting back to the Forum..
Again, great news and that includes Android 9...and to add to yours my XA2 is syncing every time I open the App..Stiil only Android 8.0.0
@Hippy996 wrote:Bought the xz3 with Android pie and working just fine (at the moment). Thanks for all the replies 🤗
11-17-2018 06:34
11-17-2018 06:34
Same here. Cant sync ionic with xz3. Hm mm....cant find the solution????
11-17-2018 08:22
11-17-2018 08:22
I have had no problems at all since I installed the app on my xz3. Syncs instantly with notifications sending to the ionic, it is always always up to date with sleep and exercise in the app.
Try deleting and reinstalling the app and the ensure settings for all day sync etc are enabled. Other than that you need someone who is cleverer than I 🤔
11-17-2018 08:49
11-17-2018 08:49
@MrKlip when setting up you ionic what device was used?
I only ask because if this phone was able to setup the ionic it should be able to sync. And we are looking a to a no sync issue on a phone known to have worked
