05-23-2018 12:28
05-23-2018 12:28
My ionic step counter does not reset to zero at the start of each day. It was working fine earlier but since two days i noticed that. Any idea how to fix it? I updated the software today but still.
05-29-2018 07:45
05-29-2018 07:45
@Omran_Oman wrote:My ionic step counter does not reset to zero at the start of each day. It was working fine earlier but since two days i noticed that. Any idea how to fix it? I updated the software today but still.
Try a Restart and do it several times if necessary.
05-29-2018 08:49
05-29-2018 08:49
A warm welcome to the Community @Omran_Oman! It's pretty weird that your Ionic isn't resetting your steps daily.
Just as @SunsetRunner mentioned, please restart it to avoid this from happening in the future. If this happens again let me know.
Keep me posted!
07-13-2018 01:11
07-13-2018 01:11
Hi, thanks for the advise. I tried restarting my ionic and the issue reolved for quite some time but again since two days the steps counting does not reset to zero by the start of the day. I updated the software after having this issue again but still. Is there anything else I should do?
07-14-2018 11:11
07-14-2018 11:11
Thanks for getting back @Omran_Oman! In this case, I've shared your post with our Support team, they will continue assisting you on this matter as this shouldn't be happening.
Hope this helps!
07-21-2018 10:49
07-21-2018 10:49
I have this same issue. I’ve reset it about 4 times now
07-21-2018 10:51
07-21-2018 10:51
I’ve had this issue for the pass 2 months. Usually a factory reset on the watch will fix it momentarily. But once again this morning I did a factory reset and as it put it right back up it still show the over step count and Did not reset
07-21-2018 11:36 - edited 07-21-2018 11:37
Hi,
After getting guidance from fitbit support team, I found that the over-stepping was due to vibration from my room's AC since I am staying in portable cabin at work. Keep your ionic away from vibration or strong air blowing.
07-21-2018 11:49
07-21-2018 11:49
07-24-2018 15:18
07-24-2018 15:18
Welcome to the Community @JanieK! Thanks for following the advice provided by @Omran_Oman. I'm glad to hear that it started working as normal, right after you weren't on your room and the AC that caused this.
Did it stopped showing extra steps @JanieK?
Catch you later!
