08-02-2018 23:26
08-02-2018 23:26
My ionic is stuck on connecting with tracker... I have in paired it with my phone and re paired it but it is still not working... is there an issue with my ionic?
Best Answer08-02-2018 23:50
08-02-2018 23:50
First thing to try when a fitbit misbehaves is a restart using the following procedure:
It does no harm and can sort out all sorts of issues. You might need to give it a few tries though as it's known to not always work. You might also try restarting your phone.
08-02-2018 23:50
08-02-2018 23:50
01-03-2019 05:35
01-03-2019 05:35
Remove all other bluetooth items from vicinity, whether they are on or off...
