08-14-2020
12:36
16:14
SilviaFitbit
08-14-2020
12:36
16:14
SilviaFitbit
Fit bit please use the correct calculation and update all the fitbits - see below
Calculator
| Weight |
lbs
kg
stone
| Hours |
| Minutes |
| Tubing, floating on a river, general | 2.3 | 165 |
| Treading water, moderate effort, general | 3.5 | 251 |
| Backstroke, recreational | 4.8 | 344 |
| Breaststroke, recreational | 5.3 | 379 |
| Water areobics, water callsthenics | 5.5 | 394 |
| Laps, freestyle, front crawl, slow, light or moderate effort | 5.8 | 415 |
| Lake, ocean, river | 6 | 430 |
| Leisurely, not lap swimming, general | 6 | 430 |
| Sidestroke, general | 7 | 501 |
| Synchronized | 8 | 573 |
| Crawl, medium speed, ~50 yards / minute, vigorous effort | 8.3 | 594 |
| Backstroke, general, training or competition | 9.5 | 680 |
| Treading water, fast, vigorous effort | 9.8 | 702 |
| Laps, freestyle, fast, vigorous effort | 9.8 | 702 |
| Crawl, fast speed, ~75 yards / minute, vigorous effort | 10 | 716 |
| Breaststroke, general, training or competition | 10.3 | 737 |
| Butterfly, general | 13.8 | 988 |
How many calories are burned while swimming? Formula
Calories burned per minute = (MET x body weight in Kg x 3.5) ÷ 200
“MET” is a measurement of the energy cost of physical activity for a period of time. You can find an activity’s MET on the chart above.
A task with a MET of 1 is roughly equal to a person’s energy expenditure from sitting still at room temperature not actively digesting food.
A task with a MET of 2 uses twice as much energy as a task with a MET of 1. A task with a MET of 10 uses 10 times as much energy as a task with a MET of 1.
16:18
08:29
08-15-2020
16:18
08:29
@arryasbo Hey there. Thank you for taking the time to share this information in the forums.
Fitbit devices combine your basal metabolic rate (BMR)—the rate at which you burn calories at rest to maintain vital body functions (including breathing, blood circulation, and heartbeat)—and your activity data to estimate your calories burned. If your device tracks heart rate, your heart-rate data is also included, especially to estimate calories burned during exercise. The number you see on your Fitbit device is your total calories burned for the day.
If you would like to change the way calories burned are tracked, you may want to post your idea in our Feature Suggestion board, those are reviewed by our team and the status will change based in Fitbit plans.
I'll be around if you have any additional questions.
