11-05-2017
10:37
12:52
DavideFitbit
11-05-2017
10:37
12:52
DavideFitbit
Has anyone had problems with syncing this new watch with their Samsung 8+
11-06-2017 03:26
11-06-2017 03:26
I suggest you search the threads. I've read of success with the S8 somewhere and also problems. There are enough posts on the matter if you look.
11-06-2017 03:32
11-06-2017 03:32
^^ Yup ^^
Best Answer11-06-2017 09:19
11-06-2017 09:19
Initially I had no issues with my S8+, but I have noticed as the Fitbit app updates, the syncing isn't as good as it was in the past when I first got it. I am still playing with it, but once in awhile I have to force stop the Fitbit app and that helps. I do have All day sync turned off, but I have left Always connected on to see if that ensures notification still work.
Best Answer11-06-2017 10:03
11-06-2017 10:03
@ratcityrain wrote:Initially I had no issues with my S8+, but I have noticed as the Fitbit app updates, the syncing isn't as good as it was in the past when I first got it. I am still playing with it, but once in awhile I have to force stop the Fitbit app and that helps. I do have All day sync turned off, but I have left Always connected on to see if that ensures notification still work.
Always connected/all day sync has no effect on notifications. Turn them off.
Best Answer11-07-2017 08:34
11-07-2017 08:34
That's what I thought, but below the always connected it states it improved reliability of notifications, etc so I left it on. I have now turned both off to see if it works better.
Best Answer11-08-2017 08:07
11-08-2017 08:07
Actually makes reliability of notifications worse imho combined with the other setting.
Best Answer11-08-2017 12:39
11-08-2017 12:39
I have turned both off and i'll be watching it for the next couple days. Today I got all my notifications (even gmail) so right now things are looking good
