03-20-2018 13:12
03-20-2018 13:12
I have tried the work arounds and they don't work for me. I cant update firmware because the device will not stay connected.
It seems like it syncs when it wants to but not when i hit sync.
Why does the device not sync on command?
Please do not thank me for my patience, I don't have any. I didn't buy an expensive device to have to spend hours to get it to do what you said it will.
I am so regretting this purchase, I had other options and clearly made the wrong choice.
How do I get a new tracker or an upgrade to something that works?
Admin: I don't know why you deleted my last post, but if you delete this one please specify what guideline i broke.
03-20-2018 14:40
03-20-2018 14:40
I have the same problem. It doesn't stay connected and it syncs when it wants to. If I want to sync it nothing happens. And the notifications doesn't work. And it doesn't want to connect to WiFi most of the time. I bought mine on Thursday last week. I used the whole weekend just to change the clockface and to make it sync with my Huawei p10.
Best Answer03-20-2018 15:20
03-20-2018 15:20
Same here! I can't do anything on this 300 dumb watch. Absolutly crazy!
Best Answer03-21-2018 05:30 - edited 03-21-2018 05:44
Same here 😞 Please find a solution and save us Fitbit.
https://community.fitbit.com/t5/Ionic/Somebody-HELP-Sync-Problem/td-p/2609599
Best Answer03-21-2018 05:51
03-21-2018 05:51
I had an issue where it wouldn't sync or update at all once the upgrade notice popped up.
I fixed my issue by rebooting my ionic (hold left button + bottom right button) and once it rebooted, the Ionic sync'ed just fine and the upgrade started.
Best Answer03-21-2018 06:11
03-21-2018 06:11
It's not about software update. It's about syncing... Obviously some of ionic born with this issue.
Best Answer03-21-2018 06:12
03-21-2018 06:12
Same with mine I just want to return and get my money back spent way to much for nothing my son's starwars smart watch is better than this thing
03-21-2018 06:20
03-21-2018 06:20
Well, I was just trying to offer a positive thought to try and help you sync. That is what made my device sync.
Best Answer03-21-2018 06:24
03-21-2018 06:24
Sorry @VandyCWG Please do not get me wrong. This is really annoys me. I didn't want to be rude.
