01-20-2018 16:46
01-20-2018 16:46
My ionic isnt syncing so i cant get my notifications! Why?!?
Best Answer01-21-2018 00:47
01-21-2018 00:47
@Yvetteleanne wrote:My ionic isnt syncing so i cant get my notifications! Why?!?
Because of a rare alignment of the sun, earth and moon? I don’t know and give up.
On a more serious note, a little more information would be helpful; phone used, what steps have you taken to try and remedy the problem, have you searched the forum to see if anybody else has a similar problem and if so, what steps did they take to rectify the problem.
Also, not syncing is not symptomatic of failing to receive notifications; they are different process. The problem is probably a Bluetooth connection issue (which would affect both).
Best Answer01-22-2018 18:39
01-22-2018 18:39
Hi. I have a Samsung galaxy 8. My ionic does not sync automatically and even when I go in the app it doesn't want to sync up. I do not get notification either. No texts or phone calls.
Have to say for a smart watch, my surge and tom tom worked better.
Steps to correct the issue please.
