Can the developers of the timer add a hours to it? Right now it only counts minutes and seconds. The minutes only go to 99.
I'm a flight attendant and counting back from the hour we take off is very useful.
Thanks!!
Who developed it? You would need to contact them and ask
Wendy | CA | Moto G6 Android
If you go into apps and then all apps it should tell you. Some even have an email contact.
If it a Fitbit app I would post in the Fitbit app forum
It's made by Fitbit. So no help on that really.
It's my first time looking for a solution of something so simple, and fitbits way of solving it, it's by making its costumers go talk online ? I'm so confused. Btw I have already tried to contact the developer by doing what you suggest, but it doesn't direct you to the actual email, it brings you back to a forum here where I learnt nothing about how to change that.
Useless!
Best AnswerThis should be such a basic function. Very easy software function. Regardless of what most users will use.
Best AnswerThis should be such a basic function. Very easy software function. Regardless of what most users will use. A very common use for a timer would be to remember to take a medication. I'm sure very few people take medications in 99min intervals!
