07-08-2018 18:33
07-08-2018 18:33
Is there a way to see the battery level while tracking an exercise (other than ending the exercise) I had a Surge, and now an Ionic. I often go on long distance runs or hikes and being able to monitor the battery level while tracking would be helpful.
Best Answer07-08-2018 23:39
07-08-2018 23:39
Unfortunately it is not possible. I agree with you that it is an important feature. There is already an open suggestion for the purpose so you might want to vote for it and add your comment.
Thanks
