Walk Shortcut
I logged into my Fitbit Account online and in the Exercise Shortcuts I added WALK
I did this as according to Fitbit you can then use the GPS to track your Walk just like you can your RUN, however even though I have done this on my Fitbit Account WALK isn't showing on my Ionic Device in the Exercise Category so how can you use the GPS to Track it, does anybody have any ideas.
TIA
2 REPLIES 2
@SunsetRunner, if you added it as an Exercise Shortcut in the app, and then synced the tracker, it will be in the list of exercises on your tracker. But, it will be the last exercise. In your app, drag the Walk exercise to the top of the list and then sync your tracer again. Then, when you press the bottom right button on the tracker, Walk will be the first exercise to show without you having to swipe through the exercises.
You can only have 7 and it also needs to sync before it will show on the device it self.
So make sure you only have 7 and  Walk is there. If not uncheck one to add it.
Then make sure to sync it
Community Council Member
Wendy | CA | Moto G6 Android
