01-10-2019 09:59
01-10-2019 09:59
After the most recent update the weather app won't sync. It also had changed to Celsius. I've completely removed the watch and removed the blutooth connection, re connected it all, still nothing. I've restarted the watch. Nothing. My phone has location services 'always on' for Fitbit. What's the deal?
Best Answer01-11-2019 15:53
01-11-2019 15:53
It's great to see you around @chriskerins! I appreciate the details that you've mentioned as well for the troubleshoot that you've performed.
Regarding your weather app not syncing, try the following steps:
- Confirm your weather app is set up correctly
- Your Ionic should sync in order to update the weather
- Leave Fitbit app running in the background of your phone
In regards to the weather showing on Celsius, please change the settings, by checking the instructions on this article How do I set up and troubleshoot apps on my Fitbit device?.
Hope this helps! Let me know how it goes.
Best Answer01-12-2019 00:37
01-12-2019 00:37
Sorry to jump on the post but I also have the same issue with my weather app and have done since last year. I’ve done all of the above but will still not sync. Please advise as I can’t even remove the app as it’s a bit pointless if it won’t work. Thank you
Best Answer01-14-2019 10:34
01-14-2019 10:34
Welcome to the Community @Greenlisa22! Thanks for the steps that you've performed. If the weather app isn't updating, this might be because your Ionic isn't syncing to your app. I also would like you to confirm that you've done this procedure to change the weather settings.
Let me know the outcome.
Best Answer01-14-2019 11:22
01-14-2019 11:22
Best Answer01-14-2019 13:06
01-14-2019 13:06
No sync here either 😞
Best Answer01-14-2019 14:39 - edited 01-14-2019 14:47
Ionic not updating weather information. Restarted. Resynced. Not working.
Problem started with new release upgrade. Also will not update app settings (clock face).
01-15-2019 01:34
01-15-2019 01:34
Best Answer12-09-2019 13:27
12-09-2019 13:27
Same here. Has anyone figured this out yet? Thanks
Best Answer12-09-2019 13:31
12-09-2019 13:31
