10-07-2019
14:55
06:50
SilviaFitbit
10-07-2019
14:55
06:50
SilviaFitbit
Just got an iPhone 11
fitbit don’t sync no more
when will Fitbit support iPhone 11
@Golfvall224 Welcome to the Community. Thanks for mentioning the phone you're using.
Currently, I don't have information about when this phone will be added to the compatible devices. However, Fitbit is always testing phones that could be added and updating the list. I would like you to keep an eye on this article that contains the compatible phones.
I've seen that some users are able to sync even when the phone isn't listed as compatible, you may want to try this syncing troubleshooting.
Yes please work on getting it it’s compatible with the new iPhone 11 ASAP I do like my Fitbit but I will certainly change to another device soon unless you guys can keep up with the technology thank you
Hi,
I think something is misleading here, you have stated in your message that you cannot say when the iPhone 11 will be added as compatible and to check the list of compatible phones. It states that the iPhone 11 is compatible in the list.
This is not the case, the Versa 2 constantly loses blue tooth connection and rarely obtains phone notifications due to this issue. I purchased this watch on the grounds it would work when I upgraded. Do you have a fix as yet or do we have rights to return as this is poor, had I have known I would have paid the extra for the Apple Watch.
Such a shame as I like the watch but cannot currently recommend.
Please update us ASAP.
I have the Alta and the Bluetooth sync is very very poor. I need to turn Bluetooth on/off every day to get it to sync. Notifications don’t transfer either ... presumable bc the Bluetooth isn’t syncing. Using iPhone 11 Pro Max.
I've moved on from the fitbit. not worth the aggravation. Being able to get accurate information regarding my workouts and making sure my fitbit was communicating properly with my phone are very important since my workouts are tied into work benefits which equal $$$$. bye-bye!
