Just bought an ionic.Trying to sync it but it is harder than i thought.
It looks like my wifi is off but i don't know how to turn it on .
Also trying to pair with earphones but doesn't want to.
I use a mac or an iPhone 6s .Can someone please help?
@costasm If you’re already set up, with the Ionic in your account, syncing is done by Bluetooth not WiFi, so WiFi being off is immaterial. However if you’re trying to set it up, then yes it will use WiFi to download various updates. But, the WiFi use will not be controlled by you but by the app.
Could you clarify what it is you are trying to do.
Thanks
i think i am starting to understand it now .I have managed to connect with wifi and also to download music. so i am making good progress.
