12-27-2017 01:43
12-27-2017 01:43
I've thought I bought the latest technology but found out that some of the options are limited. To say I'm furious is an understatement. Fitbit Ionic won't allow the user to enter static IP address and specific DNS servers. All my other devices that connect to my router are set to their chosen IP address, no problem. But FitBit? - no chance. How backward is that? I realize that most people just use the default settings by just typing in the router WiFi p/w via the auto DHCP setting. After saying all that, I've got a clever device??? that won't connect to my home WiFi. I've sent FitBit an email and still waiting for their response. If I get a positive result I'll let you all know what the workaround is. Maybe a firmware update is what I can only think of...
12-27-2017 04:10
12-27-2017 04:10
It seems that the WiFi on the Ionic is to be used to update the firmware and to download music from your PC. All remaining time it is connected by BT.
this is what I read and understood about this device, by the way I am OK with you, seems not to be connected with the latest system existing...
Best Answer12-30-2017 04:33
12-30-2017 04:33
I received a reply from FitBit and their answer was that they don't support static IP addresses, and with no support in the near future. That is so frustrating when I've got so many other devices in my house connected to my router with separate addresses.
You see, my main aim was to download music on to the Iconic. Once I downloaded the app for my PC, it required only the router p/w and all would be ok. There was no option to type in a new address.
Anyway, for the purpose of getting some music on the Iconic, I had to reset the router to default settings, then all was good. Of course I then had to put all my former settings back in the router again so all my other devices, such as phones, tablets and laptops could re-connect.
You're right about BT needing phone app to talk to FitBit, but WiFi also required to upload exercise routines to personal FitBit account.
Thanks for taking the time to answer my query. Cheers Colber84 🙂
12-30-2017 05:02 - edited 12-30-2017 05:26
01-04-2019 08:48
01-04-2019 08:48
But once you connect to wi-fi, you should be able to go to your router and assign a specific IP address, so even when using DHCP, the Versa will always get the same IP Address, correct?
Best Answer01-07-2020 05:42
01-07-2020 05:42
i have a Versa and am having the same problem with static ip, hard-coded DNS and wifi .. also the green light blinks ALL THE TIME whether the heart rate monitor is turned on or not... aaaaand my steps aren’t loading on a fitbit challenge — it appears when the challenge is in a different time zone.. i am very unhappy.. i had a Blaze for years and loved it.. now i am furiously unhappy !!!
