05-30-2019 03:25
05-30-2019 03:25
Just wanted to know, if I do a x-fit session do I choose "workout" or "weights" as I see there is not a x-fit exercise option available.
Best Answer05-30-2019 05:36
05-30-2019 05:36
Hello @SaPeet and a warm welcome. If the only choice is between Workout and Weights, I would choose Workout. But there are two other choices to consider. They are Bootcamp and Circuit Training. When you tap on your Ionic icon, then go down to Exercise Shortcuts > Edit > remove something > the + Exercise Shortcut becomes active > view the list of Exercise Shortcuts > customize your Ionic.
I suggest you try similar workouts with the different shortcuts. See how your perceived exertion compares to estimated calorie burns. That's the one I would use.
Laurie | Maryland
