12-26-2017 08:44
12-26-2017 08:44
The Fitbit Ionic allows the watch to control Hue lights (with both an app and IFTTT), and I was wondering if there was a way to use IFTTT to accomplish the same thing with ilumi. I tried to set up an applet, but there were no fitbit inputs I could find that met my needs. All i want to do is turn on/off my ilumi lights with my fitbit.
Best Answer12-27-2017 08:52
12-27-2017 08:52
@Sean.M If you’re using IFTTT you could try the app Switchr, which uses IFTTT’s web hooks. You might be able to set it up to send commands from your Ionic to Ilumi.
Best Answer01-29-2018 08:11
01-29-2018 08:11
I cant seem to get switchr, Ifttt and Webhooks to work. All setup as per the instructions I think, but doesnt function. Has anyone got this working? Examples please.
Best Answer01-31-2018 04:03
01-31-2018 04:03
Ive got it working now. Can now turn on my boiler from my watch! Tested it first by getting the webhook and just typing that link on a web browser. That tests that webhook/ifttt/kasa was working then put that link into switchr
