09-10-2019 16:11
09-10-2019 16:11
Was working fine, 70% battery then the next morning I could not get it to turn on. Left it charging for a day, then tried to charge via the computer, cleaned the contacts, etc. Watch is about 9 months old. From what I am reading this is a common problem and basically you are out of luck. Can anyone suggest something? I have tried holding down the power button, and every combination I can think off.
Best Answer09-10-2019 17:06
09-10-2019 17:06
I am not sure it is that common a problem, @holyduke. I have had my Ionic since they were first released, and have not had any problems with it. But, if you have had it only 9 months, not sure what you mean that "you are out of luck"? Your device should have a 1-year warranty. Have you contacted Fitbit Support to see if they can help resolve this issue?
Best Answer09-10-2019 17:13
09-10-2019 17:13
I will contact support and see if they will honor the warranty. By the looks of all the post about this watch, things are not well for the Fitbit Ionic.
Thank you USAF-Larry
Best Answer09-10-2019 17:24
09-10-2019 17:24
@holyduke, it is true that you will see a lot of posts of problems, but typically users only post negative comments. So, the number of negative posts will significantly outnumber the positive posts.
