01-19-2018 15:05
01-19-2018 15:05
I tried to pair my newly acquired level active wireless headphone with my ionic and no luck. Then I tried to pair with an iPod nano and it connected in 10 seconds. Good headphones, I might add, especially for $28. Any help or ideas?
Best Answer01-20-2018 02:26
01-20-2018 02:26
@sschoedler wrote:I tried to pair my newly acquired level active wireless headphone with my ionic and no luck. Then I tried to pair with an iPod nano and it connected in 10 seconds. Good headphones, I might add, especially for $28. Any help or ideas?
Hi @sschoedler not sure why you should have problems. However, I suggest that firstly ensure that anything the headphones have previously paired with is off (phones, nano etc). Then press the multifunction button for about 3 seconds to enter BT pairing mode (indicator light flashes red and blue) . On the Ionic, swipe across to Settings, tap and scroll to Bluetooth, tap and then tap on + New Device. It should then show Searching and Samsung Level Active should pop up.
Best Answer01-20-2018 06:10
01-20-2018 06:10
Best Answer01-20-2018 06:16
01-20-2018 06:16
@sschoedler wrote:
Thanks for the help. This is exactly what I was doing yesterday - the Ionic was finding the Level Active but it wouldn't pair. I just tried it again and crazily enough it worked. Thanks again.
Sent from my iPad
Glad you got it sorted
