as of probably a week ago, my fitbit ionic stopped syncing to my phone and thus stopped receiving notifications (yes both had notification settings on) before then I was getting notifications and syncing with no problem and in seconds. I tried to update the tracker and it crashes when it is attempting to install the downloaded update. I've tried forgetting the tracker and re-setting it up to my fitbit account, deleting and re-downloading the app, turning both my phone and tracker on and off again several times, and factory reset (and since it won't connect to my phone, it's stuck here). I have be using fitbit for 3 years now and this has been my only problem. I love this watch and I wish to continue to use it uninterrupted as I had before. What can I do?
Welcome on board @sneakyghosty, it's nice to see you around the forums! Thanks for the steps you've taken in order to sort this out, nice way to go! ![]()
Well, this usually happens when you performed a factory reset without before unpairing the device. Usually you should unpair your Ionic, forget Bluetooth (both Ionic and Ionic (Classic)) and perform the factory reset. To solve this issue follow these steps (some of them you already tried, but let's cover everything):
If you can't get started with your Fitbit device, usually a missing requirement is the cause. Carefully review the requirements below:
After making sure about that, try setting up your Ionic again. If then you're still having difficulties with the firmware update, please see: Why can't I update my Fitbit device?
Hope this helps, I'll be around if you need further help!
Best Answer@MarreFitbit, it does not work at all. It does not sync unless I restart Ionic, which is not what I paid for.
When will Fitbit fix that bug? Thank you.
