11-26-2017 03:41
11-26-2017 03:41
I have problems with syncing my ionic to my windows computer and my Phone galaxy s7 edge. some days it works good ,but some days I try to sync for many hours and it doesn't connect. if it doesn't connect quicker I bring the ionic back to the store . can you help me with this problem
Best Answer11-26-2017 08:21
11-26-2017 08:21
Sadly, most likely, no.
There are troubleshooting steps you can take, and I bet you've already done them : forget Ionic from phone's bluetooth, reinstall app, restart phone, restart Ionic; remove Ionic from account and try to add it back on.
My newest sync issues correspond directly with the new Android app update and I haven't been able to sync since Thursday. I've removed it from the account and I can't even set it up again. It hangs up on the 4 digit bluetooth code. This has happened before, when they broke something with an app upgrade. Basically, we have to wait til they realize it and fix it again.
Best Answer11-26-2017 12:06
11-26-2017 12:06
I've found that if I have more than one device (e.g. phone, ipad) in close proximity to my Ionic that it won't sync. It's almost as if it's confused about which device to sync to. Seems to resolve itself if you switch all but one device off. It then syncs to that device.
Best Answer11-26-2017 13:57
11-26-2017 13:57
I am experiencing same issue. However, I was able to reset and now all of my apps are not on fitbit. Only the clock, HR, steps, notifications. Swipe left, nothing. Swipe right battery%, screen wake, notifications. These bugs are ridiculous for a 300 device.
