Pretty bummed. I wanted to start using fitbits again after I just finally gave up after an Alta Screen Issue that others have noticed. After trying to fix my alta, I was offered a 35% discount on a new fit back. With a small wrist and wanting same form factor and advanced sleep/sensors, I was super excited to get Luxe. . . But yeah...the discount won't apply.
It says I have a month to use the discount, how do I find out. if I could extend that time or if it will be able to be applied to the Luxe.
Best AnswerI understand your frustration, @WhyMeWhy . We don’t have the answers to your questions here in the Community Forums. You could try contacting support but I’m not even sure they would be privy to Fitbit’s future plans as to allowing discounts on the new Luxe. Here are a couple suggestions:
I wish I had a better solution for you.
