04-05-2023 08:44
04-05-2023 08:44
I just got my Luxe, never had a Fitbit before. It appears that I can't use other functions while it's tracking a workout? I would like to use my countdown timer for rest periods between sets but it won't let me unless I "Finish" my workout. Unless I'm missing something here...? I hope Fitbit would tweak this so the timer can be used.
Best Answer04-05-2023 09:47
04-05-2023 09:47
You are correct. It does not have like multi-tasking processing. You might look at HIIT (interval workouts) with a timer to see if that fits your need.
Best Answer04-06-2023 07:26
04-06-2023 07:26
Thanks for your reply. Are you referring to selecting HIIT under workouts in the app? I'll look into that thanks.
Best Answer04-06-2023 08:54
04-06-2023 08:54
Yes, that's what I meant. Might not fit your needs but worth a look.
Best Answer04-07-2023 10:49
04-07-2023 10:49
Yeah it doesn't work for my intentions but thanks for the suggestion.
