Last year, I could switch out the types of exercises I use the most and also had weight lifting. Now, there is no option on my app (I’ve installed the update) to switch the exercise types, it is all pre loaded and I can’t change it. Is this new or is this a glitch? It just sucks not being able to put the right workout type in when I consistently weight lift and never use some of the pre loaded ones that now have no option to substitute out. Why?
Best AnswerHi @ashlynsteele you should still be able to add and remove exercises. Tap the battery % in the upper left hand corner > then tap your Luxe > tap Exercise Shortcuts. You may need to remove an exercise first (by swiping left, if you are on iOS), but you should see the "+ Exercise Shortcuts" and you can tap that to add more!
This video is from the old version of the app, but the steps are very similar if you want a visual guide.
