Fitbit Luxe screen is too small
Screen is not displaying full size
how do I fix it?
4 REPLIES 4
If you mean the dark area above and below the display, that not really part of the display and cannot be adjusted.
I don't understand why fitbit did not use the entire screen face available to them as part of the fit bit luxe display instead of leaving a dark part above and below the current display. What a waste. Making use of the entire face would allow for text to be bigger and easier to see. Cheaper products of the same size (not fitbit) use the full screen.
Hi @Olleypeepee  the original poster put that up in August. There was an update in October that changed the font size. There is a noticeable difference with the size of the letters and numbers now.
Stepping in the U.S.A. since September 2013. Android 14
I would hate to see what it looked like prior to Dec 2021, as its still terrible and i don't wear or need glasses. Plus there is still a black section above and below (the entire face) that is wasted. There is still only a box in the middle of the entire watch face being used.
