Food Should be listed alphabetical to avoid duplicates and triplicates from being added to the list. I now have Turkey pepperoni listed 4 times because I could not find it in the list quick enough. Please fix in your next update thank you
Best AnswerHi, @ladyknight1989, welcome to the community, you may find the best place for your feedback by posting at Fitbit Community. Use the search bar & enter "Food Tracking" to see suggestions on your issue. You may find one that merits your vote but it's quite easy to enter a detailed suggestion of your own.
You may find this article of some interest How do I track my food with the Fitbit app? - Fitbit Help Center, I apologise if you have already seen it. Using the food tracker is quite time-consuming whichever programme you are using as you will initially have to populate it with the food you eat. I'm very much a creature of habit & find that after adding custom food as meals with clear labels it takes about two weeks to recycle all of my choices after which it's much simpler.
You might find this thread of interest - Disappointed in new calorie/food tracker - help? - Fitbit Community
I wish I could be more helpful, it's worth the effort though.
Cheers
Gr4ndp4 | UK
