06-14-2023
07:59
14:48
JuanFitbit
06-14-2023
07:59
14:48
JuanFitbit
Hopefully I can get some help!
I had to get a new Luxe (old one stopped working and was beyond warranty); the new one will not vibrate during the half-way mark of a run/walk. I have turned on the vibration to highest setting and even watched it as I reach 1.5mi (during a 3mi run) or 2mi (during 4mi run), etc--it *sometimes* shows that I have hit the halfway mark on the screen (with a red circle around the distance) but never vibrates. It does vibrate when I hit my zone minutes.
Is there any setting I can change to make it vibrate during this?
06-14-2023 14:24
06-14-2023 14:24
@MBRMK Hello! When you start your exercise, are choosing an exercise goal before you start the activity? You need to swipe up on the screen and you'll see "Set Goal", then choose which type of goal metric you want and then it'll notify you half way through the activity with a vibration that you're halfway.
If you're doing all of that, my next suggestion would be restart the Luxe and see if it'll work after a restart.
I would also make sure the Luxe isn't in Do Not Disturb, Sleep Mode, or Exercise Focus in the settings.
06-14-2023 16:44
06-14-2023 16:44
I am setting the goal--that's how I know it should be vibrating at the halfway mark. It's definitely not in Do Not Disturb/Sleep or Exercise Focus setting (although I'm not familiar with that last one?). I can restart; was hoping to see if I could avoid that!
06-16-2023 08:43
06-16-2023 08:43
Ok--update: I reset and have made sure that everything is set up correctly--STILL NOT WORKING!
I also did an online chat with the help desk--and was told by the person that he has no idea that the Luxe vibrates at the mid-point of an exercise goal; and that he doesn't think this is an actual thing.
Help community? I will try and do the help desk again when I have time, but it was a VERY long conversation....
