Luxe is not syncing
ANSWERED
Luxe is not syncing to other apps. Also will not display floors, steps, calories and miles at the same time as it used to do this.
1 BEST ANSWER
Accepted Solutions
Hi there, @Bradfordd. Welcome to the Community Forums.
To better assist you, would you mind letting me know which apps are you referring to?
If your Luxe is not syncing to the Fitbit app, see Why won't my Fitbit device sync?
As for the stats not being displayed, please restart your Luxe as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
1 REPLY 1
Hope that helps.
