07-09-2023
01:27
04:22
07-09-2023
01:27
04:22
My Fitbit Luxe used to down load all my sleep data to my iPhone each morning. Now it doesn’t pickup my heart rate when sleeping.
07-09-2023 04:10
07-09-2023 04:10
Hi, @Auntyjan welcome to the community, May I suggest you check you have not inadvertently turned off HR on your Luxe? From the clock screen swipe down to & touch settings>swipe up to Heart Rate, check the slider is in the on position. Swipe right twice to return to the clock screen and monitor HR to ensure it is working (you should also get the flashing LED on the back)
You may be interested in this article How do I track heart rate with my Fitbit device?
Let us know how you get on.
Cheers
Gr4ndp4 | UK
07-10-2023 04:27
07-10-2023 04:27
Hi there, @Auntyjan. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Luxe.
As a first approach, please follow all tips and recommendations provided by @Gr4ndp4. If the issue persists, please try the following:
Bear in mind that if your heart rate is not working, your sleep stages won't show up either as this data is calculated by your heart rate readings.
In addition, I suggest checking Why don't I see sleep stages today?
07-13-2023 04:07
07-13-2023 04:07
Thank you for this advice. Unfortunately I have not been able to get the sleep score report since 1July.
