07-19-2022 08:43
07-19-2022 08:43
my luxe screen has just started behaving oddly - some of the rows of pixels are not displaying and it’s all flickery.
i know it’s hot in the uk, but even so.
i have restarted a couple of times (hard to find when you can’t read the screen).
it’s only a month old! Is this a heat issue or is mine faulty?
Best Answer07-20-2022 16:16
07-20-2022 16:16
thanks - that was a good suggestion (and was one of the suggestions from the support team), I went through support, and was suggested I took it back to store for a replacement (although store said they only swap if 28 days, and I was just outside that so contact fitbit - now waiting for someone else to check my video - although the email says 'Keep in mind that our warranty policy doesn’t include replacement for damage due to normal wear' surely in around 5 weeks you're going to struggle with sufficient normal wear to break it!).
Best Answer07-19-2022 09:13
07-19-2022 09:13
Hi, @AnnaS345 welcome, I'm wearing a Luxe at the moment (34C) and it's OK. I suggest you try a different clock face and if the problem continues talk to "Customer Support" and use the Chat facility or phone for a prompt response.
Cheers
Gr4ndp4 | UK
07-20-2022 16:16
