Luxe screen is flickering
ANSWERED
I've had my luxe for a couple of weeks and it's been great until this morning. The screen struggles to stay on (charge is about 50%). It will light up as normal and then will start to flicker and fade as if it's losing battery or something. If I tap the screen it might come on strong and then start the same flickering/fading again.
1 BEST ANSWER
Accepted Solutions
Hi there, @Aegroves. Welcome to the Fitbit Community Forums. I'm sorry to hear about your Luxe's behavior. I'll be glad to help you with this!
If you haven't done so yet, please restart your Fitbit device as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
1 REPLY 1
Hope that helps.
