10-19-2023
07:45
16:17
10-19-2023
07:45
16:17
I have had trouble recently not receiving phone notifications, and I think the problem is it keeps disconnecting from Bluetooth. Anyone else have this issue? This morning I can’t get it to connect to Bluetooth at all. I have restarted my phone and turned Bluetooth off and on - still no luck. Not sure if it’s a phone problem or Luxe problem, but I tend to think Luxe because I can connect to other Bluetooth devices no problem.
Best Answer10-19-2023 16:18
10-19-2023 16:18
Hello there, @Susmitch. Thanks for stopping by in the Fitbit Community Forums. I appreciate you've taken the time to troubleshoot the issue with your Luxe before reaching out. I'll do my best to help you with this!
In addition to the steps you've done, please try the following:
With the steps above, what I want you to do is to pair your Luxe first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer10-21-2023 08:29
10-21-2023 08:29
why shoud it require so many steps ? This happens several times a day
fitbit needs to fix the problem
Also, why should I pay another company "Answer" when the problem lies with fitbit
10-21-2023 11:52
10-21-2023 11:52
Hi there, @kikitoto. Thanks for stopping by. I understand where you're coming from. I appreciate your feedback and bringing this to our attention.
I feel you when it comes to try all the steps I recommended above, however, doing those steps should help in the long term. I've encountered similar issues when I update my computer or my TV apps, it's not just with the Fitbit app. Nevertheless, I really understand how you must be feeling as this just started happening overnight.
Please feel free to try the steps I recommended and let me know if the issue persists in the next couple of days.
Best Answer10-21-2023 17:44
10-21-2023 17:44
Best Answer10-21-2023 22:05
10-21-2023 22:05
Same issue all day, have reset multiple times. Bluetooth connection lost multiple times per day. Today will not connect
Best Answer10-23-2023 07:15
10-23-2023 07:15
Thank you for the tips. I did eventually get it to connect, but it repeatedly becomes disconnected. I am not going to do that huge list of steps multiple times a day, especially deleting every other Bluetooth device from my phone. That is not sustainable. It also makes the Fitbit completely useless for phone notifications because I never know if it’s connected or not. I’ve gone hours with no notifications only to find I have missed calls and messages that my Fitbit missed because it disconnected itself again.
I’m sorry others are also having issues, but at least now I know it is a Fitbit issue.
