12-05-2022
23:42
12:34
EstuardoFitbit
12-05-2022
23:42
12:34
EstuardoFitbit
Hi my screen is not showing any color. It still remain same even after restart or change the clock. Pls advise
12-06-2022 08:44
12-06-2022 08:44
Hi there, @Woonnnn. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Luxe and the image attached.
As a first approach, I'd recommend checking if your Luxe is in sleep mode. When sleep mode is on:
For more information, see How do I navigate my Fitbit device?
If the above doesn't describe your issue and in order for me to better assist you, please confirm that you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?.
Hope that helps.
12-07-2022 17:25
12-07-2022 17:25
Make sure screen display its on normal or Max and not Dim.
12-08-2022 19:03
12-08-2022 19:03
Hi all, it is not in sleeping mode. Also not due to brightness setting, it is not dim, it is no colour at all. Tried to set brightness to max, still look the same.
