In interval training mode, my Luxe doesn’t vibrate between movement and rest periods. No notification at all in between rest and movement. I can’t find any settings where I can add vibration. Does anyone know?
Best AnswerHi, @KristinaBerg , the Luxe is designed to vibrate between rest and movement intervals and there is no setting to add this. It is possible that while you were concentrating on your workout you missed the vibration (that definitely used to happen to me when I was running). There is a setting on the Luxe to make the vibrations stronger - from the clock screen on the Luxe swipe down until you come to the settings menu, tap to open, then swipe up to find vibration. Tap to toggle between normal and strong. I would recommend strong for a workout.
Having said all that, there seems to be something strange with the interval setting - it looks like a bug has set in with the time settings and the interval repeat, so the bug may also be affecting whether it vibrates. I will report this to Fitbit and hopefully they will look into it.
Best AnswerHi @Julia_G ! Thanks for your reply! It’s good to know that there at least SHOULD be a vibration (ingerval mode would be pretty useless otherwise).
Perhaps it’s the bug you that you mention, because there was no vibration at all in between rest & movement.
