11-16-2024
02:54
11:24
11-16-2024
02:54
11:24
I have changed the wall plug, cleaned the charging surfaces, left it for several hours, restarted the device, left it for several more hours, changed the outlet I’m charging from, pressed the little button on the USB connector 3 times. When I put the device on the charger it was vibrating to show it had connected properly but it will not charge the battery at all and now it’s totally dead and unresponsive. I’ve been trying for over 24 hours and nothing is helping so far.
Best Answer11-18-2024 11:25
11-18-2024 11:25
Hi there, @Luicy. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Luxe is still not charging. I understand your cocnern, I will do my best to help you with this!
I've seen you contacted our Support Team after posting here and they already offered some troubleshooting steps, my best advice is to keep the conversation directly with them so they will tell you what is the next step in case that the recommendations provided haven't worked.
Thanks in advance!
