10-07-2024
07:17
08:59
10-07-2024
07:17
08:59
When I charged my Luxe yesterday, it flipped out. The time was behind exactly 5 hours. I tried various things to get it fixed: restarted my phone, turned off and on bluetooth, uninstalled and reinstalled fitbit. Now it will not sync or pair either, and the time is still off. Any ideas? I've had the Luxe and phone, a while.
Hi there, @koikeeper. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Luxe is still not syncing or pairing. I understand your concern, I will do my best to help you with this!
As a first approach, I'd recommend checking if your mobile device meets the requirements to properly operate with your Fitbit device. For more information, see Fitbit Compatible Devices.
In addition to the steps you've done, I'd recommend trying the following steps in the order listed:
With the steps above, what I want you to do is to pair your Luxe first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone. Once you manage to sync your Luxe, the time should be corrected as your Fitbit device uses the time of the device you're syncing with.
