Sleep / Wake Mode for Luxe
ANSWERED
I have just purchased a Luxe Fitbit and in the process of setting up.   I did look through the forum to see how that in order for the Wake function to work, with turning my wrist; the Sleep mode needed to be off.
So does this mean, I will need to tap on Sleep Mode every evening?  I did go into the Settings and the time is set up, for when I wanted to be in Sleep Mode.  When I go back to the first screen, it shows as "on" though.
Is there a way to have both of then enabled?
Thank you,
Jen
1 BEST ANSWER
Accepted Solutions
I figured it out.  I had the Sleep Schedule set, so that is why it was confusing.  I did a test and all is good.
I wasn't sure how to remove the post.
2 REPLIES 2
@jen1016 I'm glad you were able to fix that problem. I've marked your response as the Best Answer, so that others may benefit from it.
Community Council Member
Amanda | Wyoming, USA
Pixel Watch 3, Inspire 3, Sense | Android
