I realize this may be unpopular. Before I bought the Luxe, I had a generic tracker about this same size. Instead of trying to fit all the text across the short side of the rectangle, like Luxe, they turned it so the text filled the long side. You fit much more that way, and the font is bigger too.
I only tried this Luxe because my band was wearing on my old tracker, and I couldn't see it well in sunlight. Luxe's display is clear in sunlight, but it is a small part of the whole rectangle, and then of course you try to squish everything in on the short side, so the font is tiny on top of that.
I'd be happy with a clock face and then I swipe to see steps by itself on its own screen and heart rate by itself on another screen, so it's bigger. I'd also be happier if the display took up the whole rectangle so it wasn't so tiny. .
I bought this because I don't want a large smartwatch. I want this size to track my steps and heart rate, but I also want to be able to read it.
Hi @Daphnefit99 there was a firmware update for the Luxe where the font is larger. Did you update yours?
Best AnswerI did it and the result is that it lost all the luxury aspect, it seems very umprofesional.
Alta had the screen rotate 90 degrees, it would be nice to have it as well on Luxe.
